Disables NTP on a VLAN.
| disable | Disables NTP on a VLAN. |
| vlan-name | Specifies the name of a particular VLAN on which to enable or disable NTP. |
| all | Enables or disables NTP on all VLANs. |
| vr | Specifies disabling NTP on a VR. |
| vr_name | Specifies the VR name to disable NTP on. If a VR name is not specified, the VR of current command context is used. |
NTP is disabled on all VLANs by default.
N/A.
The following command disables NTP on all VLANs:
disable ntp all
The following command disables NTP on specific VLAN:
disable ntp vlan vlan-1
This command was first available in ExtremeXOS 12.7.
The vr option was added in ExtremeXOS 22.2
